JKS MANUFACTURING 2570 2007-2009 REAR ADJUSTABLE COIL OVER SPACER SYSTEM FOR JEEP JK
By design coil springs are more sensitive to load changes because they lack the inherent friction produced by leaf springs. As a result simple modifications like installing a bumper winch or second battery can easily affect vehicle ride height enough to create tire clearance problems.
Features- Variable length coil spring spacer allows convenient ride height
- Compensates for uneven load distribution spring settling and sagging
- Instantly increases vehicle ride height upon installation for immediate benefits
- Eliminates need to replace coil springs to accommodate future modifications
Specifications
Price: 513.01
