aFe Control is proud to release the PFADT Series Featherlight Adjustable Drag Race Coilover System for the 1997-2013 C5/C6 Corvette. The Drag Race spec coilovers are specially tuned for the needs of drag racers and feature special valving and spring rates. Designed as a complete solution the Featherlight Coilovers will allow you to remove the transverse leaf springs and OE shocks on your Corvette yielding a true independent suspension which eliminates the “crosstalk” and harsh ride that the OEM suspension is known for. Both ride height and damping are easily adjustable in this design allowing for fine tuning your Corvette’s stance and ride quality. Packed with features the coilovers are precision CNC machined from 6061-T6 Aluminum hard anodized. The mono-tube construction utilizes a floating piston to separate the oil and nitrogen gas allowing for predictable handling and a consistent feel.
Features
