aFe Control is proud to release the PFADT Series Featherlight Adjustable Coilover System for the 1997-2013 C5/C6 Corvette. Designed as a complete solution the Featherlight Coilovers will allow you to remove the transverse leaf springs and OE shocks on your Corvette yielding a true independent suspension which eliminates the “crosstalk” and harsh ride that the OEM suspension is known for. Both ride height and damping are easily adjustable in this design allowing for fine tuning your Corvette’s stance and ride quality. Packed with features the coilovers are precision CNC machined from 6061-T6 Aluminum hard anodized. The mono-tube construction utilizes a floating piston to separate the oil and nitrogen gas allowing for predictable handling and a consistent feel. The CIRC (Concentric Integrated Remote Canister) System more than triples the gas volume over a standard coilover resulting in consistent operation over a wide temperature range and throughout the stroke. Integrated into the CIRC head is the BOA (Ball on Axis) upper mount which is a completely sealed design allowing full articulation of the Corvettes suspension and offers a durable quiet mounting solution without travel loss as is common in other clevis style mounting systems.
Features
